Hi There
I have been trying to cut the key signal to black whilst a scene is running, whilst maintaining my fill signal.
The method I used was to disable Alpha in the render options node, shown in the attached file.
When doing this in designer and showing the key, the signal is cut as I would expect.
My issue pops up when running as a broadcast scene, the key signal instead of cutting, sends the RGB channels as a key.
Has anyone else encountered this issue, and if so what was your method for solving the problem?
Does anyone know a better way of removing the key signal, whilst maintaining fill?
- Ciaran
Toggle Key Signal in Broadcast
- RenderOptions.PNG (6.94 KiB) Viewed 3792 times
Ciaran
Kinetic Pixel
Software Developer
Kinetic Pixel
Software Developer
Re: Toggle Key Signal in Broadcast
Just bumping this topic.
Does anyone have a solution for the above issue?
- Ciaran
- Ciaran
Ciaran
Kinetic Pixel
Software Developer
Kinetic Pixel
Software Developer
u-double-u
If one could access and animate the paramaters in the "mapping" section of the texture and then seamlessly switch between PMAlpha and Off in the target-tab...
