as discussed in the last Ventuz meeting here are some features i like to see in the next Ventuz version
Here are some features i´m missing.
1. Ventuz Exporter
Need this feature many times in different kind of projects .
1. get my lost 3d data back from a old project
2. adjust new 3d elements in the ventuz rearranged scene
3. for the new particles on a spline to create the spline in the 3d scene
4. get 3d data out of a ventuz scene from a different client which has not the source files anymore
Features:
- Geometrie exporter for selected meshes or the whole scene as OBJ, FBX or DAE
- Camera Exporter with Animation
- Object with Animation
- Basic Material and UV´s support
2. 360 Movie Exporter
In the render to disk i like to rende a 360 movie from my scene as spherical map for vr cases or vr playouts.
3. Working Importer for Anitmations
Currently it´s not possible to get animated 3 mesh data (Dae or FBX) into Ventuz 5 without a workflow over Ventuz 4.
I´m working with Maya, Max and Softimage. For Cinema it´s ok but i don´t use it so often.
Please fix this for the next release
Other features:
- Import Mesh Sequences from files like a obj seqeunce.
- Import Camera with animations from Autodesk Tools (FBX)
4. Material Feature (Amount Texture)
Please add a extra texture for the Vertex Noise or Perlin Vertex Noise to adjust the amount via black / white texture.
This would be very nice to let a texture control where the noise is more or less active. UV should be adjustable for the texture.+
More will follow soon
Thanks and i hope you can add some of these features into the next release or into a update.
Best regards,
Tom
