Would be very helpfull in some cases.
Thx and Greetings
Christian
For eg. i think i could use this array to feed it into the Particle Node to use the Array for adjusting the position of the particles. At the moment it is not possible to adjust the position of a particle by a texture.I could add a node that essentially does what the DMX Texture node does but outputs an array instead of DMX but it'd be nice to know what use cases you imagine.
