Hi there,
I used Ventuz 3 Express until now - as it was free of charge.
I am thinking of moving on, buying a licence - btw, where can I - and like to continue with Ventuz 5.
But - Is it possible to use projects, scenes or anything written in Ventuz 3 to be used or imported in Ventuz 5. Any Workaround - available maybe.
As I did some big work - several lectures - with it and it would be immpossible to do it all over again from scratch with V5.
In that way it is some kind of descision making for me if to stay or moving to another application as beside the lic of V5 is not a cheap one - so I heared.
thx for help
tp
import from ventuz 3 ?
Re: import from ventuz 3 ?
Hi testpilot!
You will not be able to load your scenes in Ventuz 5 because they have been created with a free version. If you purchase a V5 license we will convert your scenes so that they can be loaded.
But it's possible that they will not work as expected.
Some bugfixes or necessary changes in Ventuz 4.0.0 & 5.0.0 were BREAKING CHANGES (see http://www.ventuz.com/release-notes).
These changes may affect logic and rendering.
So it's highly recommended to test the scene after conversion.
Thanks Carol,
may I ask some questions.
You said, that it would be possible - although only to some extend - to convert Scenes.
Does ist mean, if I buy a licence, it is possible by only sending you the scenes-files for converting.
Is there a limit in the amount of scenes to be ported from your side.
As I only used standard nodes beside some math -nodes - no specials at all - would it be, that the scenes would load but not functioning properly if there are problems in converting at all.
How would the process be to port those scene-files.
I am asking because, that it is not so much a problem changing some notes rewriting this and that but for example redefining imported geometries with axes nodes and their texture would be a drama – because there are a lot in my presentation. Same holds for key-framing of course. For me it is important that it would load anyway – fine-tuning is just a matter of time.
And I have to ask another question. How would be the future. There are several software packages around the world. Most of them are compatible to some extend to previous versions. What is, let’s say some Ventuz 6 coming along, my licence has to be renewed or is not valid and I skip this version and join again at Version let say 7, would I lose my work. Just to have an idea. What are the politics in this case.
Sorry for the questions – it is not the price which I am concerned - although I am really thankful to use V3 express (a wonderful Software !) all those years - it is the work of month and years I’d like to save and like to continue to use in the future.
Thank you very much
tp
Thank you very much
tp
Yes!Does ist mean, if I buy a licence, it is possible by only sending you the scenes-files for converting.
No, only physical limits like disk-storage and internet connectionIs there a limit in the amount of scenes to be ported from your side.
Conversion always works! But some node may not work like before due to the already mentioned BREAKING CHANGES!As I only used standard nodes beside some math -nodes - no specials at all - would it be, that the scenes would load but not functioning properly if there are problems in converting at all.
After purchasing a license you send us all scenes you want to have converted; we convert them and send them back.How would the process be to port those scene-files.
Animation and geometries imported are not affected. This will definitely work.I am asking because, that it is not so much a problem changing some notes rewriting this and that but for example redefining imported geometries with axes nodes and their texture would be a drama – because there are a lot in my presentation. Same holds for key-framing of course. For me it is important that it would load anyway – fine-tuning is just a matter of time.
It would be the same as converting from 3 to 5. Except that you would not need a conversion but only need to load the scenes in V7 and test if they still work. Ventuz will always be able to load old scenes...And I have to ask another question. How would be the future. There are several software packages around the world. Most of them are compatible to some extend to previous versions. What is, let’s say some Ventuz 6 coming along, my license has to be renewed or is not valid and I skip this version and join again at Version let say 7, would I lose my work. Just to have an idea. What are the politics in this case.
I would recommend that you download the latest V5 and request a PLE license to test what happens if you load your old scenes. The PLE can load all formats - even the Express formats.
BUT do not save your scenes with the PLE!!! You want to able to load them in a licensed version anymore.
