How to - Path
Posted: 10 Oct 2017, 08:49
Hello Hello,
its possible to have splines working in ventuz now - you can use them to bind or attach anything to the path.
right now it makes sense to use this feature for the particle system.
Remember: Whenever you receive a new ventuz version you should also update the Cinema4D livelink plugin - the installer can be found in the installation directory of ventuz.
How to get Splines in Ventuz:
1. Create a path with the spline tool in C4D and use the Ventuz Tag to send the Spline Data (should be enabled per default already)
2. Use the Geometry import live node to import that path into Ventuz
3. The result will be an axis and the content will have a path node linked
4. Use the EvalPath node and bind that that to the Path
5. The EvalPath will output XYZ position and a Worldmatrix. Both could be used to animate Objects along the path, you can use the Position Value to define the position along the path
6. Use the "Position: Manual" to bind the X/Y/Z axis to the EvalPath node
7. Animate or scrub the Position value for the EvalPath to change the Position along the path
Please check out that feature and give us as much feedback as you can :)
Thanks and best creative regArts
Re: How to - Path
Posted: 18 Oct 2017, 08:25
by _aTom_
Hi Dennis,
i tried to load the example scene with the spline but i see nothing on my screen. No Spline and no Particles.
I haven“t installed the Cinema Plugin right now. Is it necessary to see the spline demo?
Best regards,
Tom
Re: How to - Path
Posted: 18 Oct 2017, 08:38
Yes we have an issue with the example scene.. something has changed in the last minute. Sorry for that.
The spline is more to the right (move the cam to the right) increase the ParticleSize and so on...
So in fact its better to start with a new fresh scene and give it a try on your own! :)
Sorry for the issues!
Best creative regArts
