Multiple Machines with 3D Layer Reference
Posted: 29 Aug 2017, 10:59
Hi Ventuz Team.
I have a concern about my final output with a specific configuration in Ventuz which might be more hardware related.
I have 3 seperate Machines.. each one outputs 1920x1080 resolution .. and are aligned next to each other (configuration.jpg)
On My Cluster preview (Cluster Preview.jpg) .. I can see everything perfectly fine: I have a 3D Layer reference on the 2nd Machine (which is in the center), while the layer it is referencing is on the 3rd machine (furthest right output)
the issue happens when I Select My Second (Middle) Machine preview from the stage editor, The Layer is completely blocked (Screen 2.jpg).
Currently I cannot test this with 3 actual machines until the due date of this project, but I need to know if 3D Layer reference will be visible in the final output like my Full cluster preview.
If there is something that I need to do in Designer for this to be functional please let me know..
