Rounded Rectangle Corner Radius
Gsand
Post by Gsand » 11 Aug 2017, 22:45
I'm looking to a 1 pixel outline rounded rectangle but I don't seam to see any way to increase the radius of the rounded corners in the "Rounded Rectangle" node with out making the outline larger.
Is this possible in Ventuz?
Greg
Gsand
Re: Rounded Rectangle Corner Radius
Post by Gsand » 11 Aug 2017, 23:54
Something like this outline
Screen Shot 2017-08-11 at 3.45.14 PM.png (6.47 KiB) Viewed 7102 times
Post by Karol » 14 Aug 2017, 10:17
Hi Greg!
The Rounded Rect unfortunately does not have an 'inner roundness'.
You can fake it with an according texture (see attached VZA).
But I don't know if this meets your technical demands...
innerRoundRect.vza
(12.75 KiB) Downloaded 559 times
Joe Styles
Post by Joe Styles » 15 Aug 2017, 14:34
Thanks for that Karol a good 2D solution! It would be great to have a built in 3D solution.
We often use geometries to create a 3D frame which we can change the width and height on. See the attached archive, hope that helps Greg.
The only issue is that when we alpha it out you can see the joins and sometimes you do get aliasing issues at the joins.
Rounded Box Frame.vza
(14.71 KiB) Downloaded 530 times
Joe Styles
Kinetic Pixel
lerou
Post by lerou » 16 Aug 2017, 10:14
I often use stencil for that.
RoundedFrame.vza
(18.86 KiB) Downloaded 539 times
Gsand
Post by Gsand » 25 Aug 2017, 07:09
Thank everyone for your suggestions.
2D would be a great solution Karol but like Joe mentioned I would need to dynamically change the dimensions of the rectangle bases on content.
Good Idea for a 3D frame Joe, thanks
Thanks Lerou this is the type of thing that I would use, I'll dive a little deeper to get a grasp on what all happening in there.
Thanks again all!!
