Hi Guys,
I have checked this on two machines. No User Interface in the Live Options Window showing in either Designer, or inside the Configuration Window when using a VPR.
Please fix ASAP as job looming in 1st Week of June.
Live Options - No User Interface !!
Re: Live Options - No User Interface !!
Hi Peter!
Which version?
Did you checked the logs? Especially VentuzConfig.log when you use the Config Editor.
How does the control look like? Screenshot!?
Is VMS running?
Which version?
Is VMS running?
mrmacmusic
I'm seeing exactly the same problem – the Live Options are all missing both in Designer and in the Configuration Window (when using a VPR)... however I can confirm (at least on my systems) that this only happens if an NDI Input is active in the AV Configuration. If I change the configuration to a DVI input source (rather than NDI), the Live Options re-appear!
I can replicate this on two different machines – one VBOX, one HP laptop (both fresh installs of Ventuz 5.03 and Newtek NDI tools) – and both behave in exactly the same way:
AV Config includes NDI Input = Live Options missing
AV Config includes DVI (or other) Input = Live Options available
Hope this helps locate the problem?!
Thanx
i could reproduce this ...
sorry
RegArts
sorry
RegArts
