Hi everybody !
I wanted to know if Ventuz 5 support SLI technology or Crossfire ?
SLI supported ?
Re: SLI supported ?
Short: Nope
You can use multiple Graphic Cards with Quadro-Sync + Mosaic to add additional outputs. But this feature is not officially supported and Ventuz only uses one Graphic Card to render so the performance is always roughly the same as if you use only one Card. If you need many Outputs use signal splitters like "Datapath Fx4" . If you need much power clustering is the way to go. If you need both: combine it
