Post
								by ejgazz » 09 May 2017, 14:34
			Hi Alisa, I have recently done two projects with 5.1 audio with mixed success, but a few recommendations I can share:
Make sure you use the "audio clip" node instead of the "sounds" node
Also this is copied from the user manual:
"Audio playback nodes get their timing from the sound card. By binding the control of the audio playback node to an animation, the animation takes over the timing, and now the audio playback gets their timing from the video subsystem. Also, movie clip nodes tie the audio timing to video. Now audio and video can drift apart, and this is where audio compensation comes into play.
If audio compensation is enabled, Ventuz will try to speed up or slow down audio playback just slightly to compensate the drift between sound and video subsystem. If it is disabled, audio will skip to the right position when the difference gets too big. This can be controlled by pressing the configure button in the property sheet."
That option can be found by hitting the "configure" option on the node properties.
									Eric Gazzillo
Display Designer
Quince Imaging
