Is it possible to play a twitch stream inside of ventuz?
Luke47921
Post by Luke47921 » 14 Mar 2017, 10:45
Can I use the movie stream node to get twitch streams? Using the normal URL (e.g. https://www.twitch.tv/esl_csgo) doesn't seem to work, is there something else I need to do?
Re: Is it possible to play a twitch stream inside of ventuz?
Post by Dennis » 14 Mar 2017, 13:29
Hmm ...
Long time ago i used to watch twitch streams with Ventuz.
Cant really remember how i managed it...
but .. there is an app called livestreamer on github which works with VLC.. maybe you can get a proper stream by using it together with ventuz?
https://github.com/chrippa/livestreamer/releases
regArts
:ugeek:
edit:
also worth a read:
https://www.johannesbader.ch/2014/01/fi ... roadcasts/
Luke47921
Post by Luke47921 » 14 Mar 2017, 16:33
Thanks for the info, but after a bit of research Twitch changed to HLS protocol a while ago so I don't think i'll be able to stream it in Ventuz
u-double-u
Post by u-double-u » 15 Mar 2017, 09:30
you might want to try NDI inputs here. Just tried an iOS-app called "WebNDI". Guess what it does...
cheers.
