Win mouse and Direct Input mouse not giving the same results
joysprod
Post by joysprod » 27 Feb 2017, 14:44
I was trying to detect a right click on a rectangle. I can only get this to function using a Direct Input mouse and yet both Expression nodes have the same expression and both are receiving A=1 and B=1 and yet the outputs are different.
detect right click.vzs
(10.76 KiB) Downloaded 596 times
lerou
Re: Win mouse and Direct Input mouse not giving the same res
Post by lerou » 27 Feb 2017, 16:16
Looks like the changed input (WinMouse R -> Expression A) doesn't update the expression's calculation and output. As a workaround throw a mover into the scene, connect its output to C in your expression. The mover will constantly change the input and force a re-calculation.
Götz_B
Post by Götz_B » 06 Mar 2017, 15:10
right, there seems to be sth wrong with the validation mechanism of the Windows Mouse Node. We will check it.
Rou's workaround works - using a mover to force the validation every frame.
But probably you don't need a workaround:
In V5.2 we added Touch Groups. In the Machine Config you could set the right mouse button to a touch group, and then make the Touch Button listen to this group using the TouchGroupFilter property.
Regards,
Götz
