Color problem HDR Layer with Enriched Text
Olivier
Post by Olivier » 24 Jan 2017, 19:55
Hello all,
If I use Enriched Block Text inside an HDR 3D Layer it seems that I don't have good color value... While it's working using Normal Block Text... The color variation is really small but I wish to have the color I asked for :)
Everything is fine using non-HDR 3D layer.
See attached file,
Olivier
Color_problem_HDR Layer and Enriched Text.vza
(21.86 KiB) Downloaded 588 times
Olivier
Re: Color problem HDR Layer with Enriched Text
Post by Olivier » 02 Feb 2017, 15:50
No answer :(
Post by Dennis » 03 Feb 2017, 10:31
Here is the answer :)
I investigated the scene and there are two reasons for this:
either we did not use the gamma correction in the right place or its a different kind of bug :)
Another hint: in V3 we used the Emissive to colorize the text in V4 we used Diffuse... therefore the diffuse in V5 is handled differently when it comes to HDR.
We will try to fix that .. :)
Sorry for the inconvenience and thanks for the report!
regArts
:ugeek:
Olivier
Post by Olivier » 05 Feb 2017, 21:51
Thank for your answer!
Waiting for the fix now :)
Olivier
Post by Olivier » 15 May 2017, 15:50
UP!
Again working on the same kind on project...
I really need to have the color I asked on all my text to match the visual identity of my client!
THX !
Post by Dennis » 16 May 2017, 09:23
Hey, please download: the actual 5.03.0 :)
The fix should be included. Tell me if not!
RegArts
:ugeek:
