I have a touch translation node that is set up like so: http://imgur.com/a/4O0Fk
When moving the node up and down on the Y axis, if i stop moving the node as Y approaches within ~0.8 of the minimum or maximum limits (e.g. when Y is at 0.5), the node will no longer move any closer towards the limit, unless i move it out of the ~0.8 range and drag it all the way to the limit.
Touch translation node gets stuck small output values
Re: Touch translation node gets stuck small output values
Hey Luke,
I recently had this problem and I edited the behaviour of the touch translation and it all seems to be fine
J
J
