Unable to install Deltacast 5.19?
If this is your first visit, be sure to check out the FAQ
Daniel Willer
Post by Daniel Willer » 19 Aug 2016, 10:43
Because a lot of people are stumbling across this issue I will quickly explain how to solve it.
During the installation of the Detlacast 5.19 driver you get an error message related to the driver signature
There are actually two ways to solve the issue.
1. Update your Windows until no further updates are availble (Maybe multiple update cycles are needed). For sure this is not what you want in a production environment because updates can always bring new issues.
2. Disable the driver signature enforcement. You can find tons of HowTo's around the web based on your windows version.
But if saveboot is disbaled in your BIOS you can also easily do it on the command line.
bcdedit -set loadoptions DISABLE_INTEGRITY_CHECKS
bcdedit -set TESTSIGNING ON
We got the following information from Deltacast:
“If you are running Windows 7 or Server 2008, the following dialog box may appear mentioning error code 52. It’s due to a Microsoft SHA-1 deprecation policy. Indeed, Microsoft will no longer allow new SHA-1 code signing certificates to be used for signing files on Windows 7 and above starting Jan. 1, 2016. Windows 7 and Server 2008 R2 will require a hotfix for SHA-256 support. Please visit https://technet.microsoft.com/en-us/lib ... ty/3033929 for more information”
Re: Unable to install Deltacast 5.19?
Post by chriss0212 » 22 Aug 2016, 17:22
No need to download a tool:
http://www.howtogeek.com/167723/how-to- ... d-drivers/
Greets
Christian
Daniel Willer
Post by Daniel Willer » 23 Aug 2016, 08:31
bcdedit is part of windows :D to edit the bootconfigration
Daniel Willer
Post by Daniel Willer » 20 Oct 2016, 13:42
Regarding the Deltacast User Guide the following Windows update will fix the issue.
Microsoft Security Advisory 3033929
Installation Guide for End Users - Deltacast
