After updating to the latest version of Ventuz, it seems you changed something in Alpha,Scale..Text Effect nodes,also the text node.When you run the text effect on multiline arabic text ( RTL) the bottom line appears first instead of starting from the top line.Also notice the alignment of the numbers are wrong.This is the same project running on V4 and V5 (The same project I oppened and rendered on V4, and then opened and rendered on V5.Now the text positions are easy to fix, but the text effect!!!!!.. Please make sure you watch the video
[youtube]https://youtu.be/WVYBc3o8b0Q[/youtube]. Please you have to fix this urgently.
ps: I tried all the possible ways on text effect, near to far, far to near, near to far invert on, near to far invert off, RTL on and off on text node . . . . . NOTHING WORKS
youtube link:
