When setting up the config and putting in the graphics adapter you have to select which display to use for output. I'm not sure the number equals the one given in the Windows Display Settings and/or Graphics Driver - I believe I've seen it differ. However it would be a great help if there was one of those nice identify buttons showing the display number on each display. I always select the wrong one(s) first.
Would be awesome!
Identify Displays in Config Editor
Re: Identify Displays in Config Editor
A button to show on the beamer the name of the display could help also.
A solo mode for several displays at the same time could help because some time we need to see the same single pattern on each output in order to calibrate.
A list view beside the rectangle screens to select overlapped display could help also.
R
R
