Help needed for using Stencils
Olivier
Post by Olivier » 18 May 2016, 12:10
I want to achieve a complicated text effect with Stencil.
First, my text is divided in 2 parts, top and bottom. Both parts are going in using a rectangle stencil n°1.
After that my text is appeared, I would like to make it disappear using another stencil n°2.
How can I achieve this effect??
See attached file,
Thank you :)
Olivier
Stencil_Issue.vza
(12.56 KiB) Downloaded 657 times
Chris
Re: Help needed for using Stencils
Post by Chris » 18 May 2016, 21:50
hey,
Not sure you can nest stencil nodes like that......
you could get the same affect using an alpha ;)
chris
Stencil_Issue_01.vza
(13.93 KiB) Downloaded 680 times
Olivier
Post by Olivier » 19 May 2016, 11:29
Thanks for your answer Chris,
I thought about this kind of solution but I really need to use a stencil, like that I can make much more different effects, like using a circle or combine more than one geometry to set my stencil...
Anyone else ??
hgoodsir
Post by hgoodsir » 19 May 2016, 12:20
What I love about ventuz is that there are so many ways to create thing, I made example using render target, masks, and text effects it may help it may not :)
Another_example.vza
(14.39 KiB) Downloaded 695 times
Post by chriss0212 » 19 May 2016, 12:58
like this??
greets
Stencil_Issue_CK.vza
(10.22 KiB) Downloaded 731 times
lerou
Post by lerou » 19 May 2016, 13:03
with stencils nesting won't work. The new stencil node will overwrite the old one.
Basically you've got two options if you want to use stencil:
1. use advanced stencil node, make complicated stuff, spend a day and get it done or not...
2. simply use a switch to toggle between your stencil setups.
I would recommend option 2. And yes, I'll give you a working example. Took 5 minutes, so probably a lot faster then option 1 ;)
Stencil_Issue_glare.vza
(14.18 KiB) Downloaded 703 times
Post by chriss0212 » 19 May 2016, 13:10
And what i have noticed:
NEVER animate size of a geometry during runtime! try ALWAYS to use an axis for changing the size! changing geometry eats resources because geometry needs to be recalculated!!!
greets
Post by chriss0212 » 19 May 2016, 13:14
another one...less nodes ;)
Stencil_Issue_CK2.vza
(9.93 KiB) Downloaded 666 times
lerou
Post by lerou » 19 May 2016, 13:20
chriss0212 wrote:NEVER animate size of a geometry during runtime! try ALWAYS to use an axis for changing the size! changing geometry eats resources because geometry needs to be recalculated!!!
Supertrue!!1!1one!
Actually the geometry has to be rebuilt, which is quick, but that might stall the whole system nevertheless. So just don't ;)
