Images don't show up when running Ventuz Presentation
i not sure what am i doing wrong but every-time i have an image or background in my Ventuz project, as soon as i export the presentation and run it, Pooooofffff its no where to be found. anybody have any ideas on why this might be happening? Than k you. oh an I am using PNG and JPEG'S. thanks in advance.
Re: Images don't show up when running Ventuz Presentation
When Exporting to .vpr make shure to select "ALL" when asking for the ressources.
Also check your image paths in the presentation. If using relative paths these refer to the position the presentation file is started in (or its working directory). If the images are not in this file structure they will not be found.
If you are constructing dynamic paths in your scene, make sure to include all textures with the ressource linker node.
You can always check the log files to see where Ventuz expects your textures to be located - this is usually a quick hint towards the right direction.
if you use a relative path like:
make sure, that you store the vpr in the root directory not in the presentation diretory!
greets
greets
Thank you all for your replies and your suggestions.
When Exporting to .vpr i did make sure to select "ALL" but for some reason, in the file structure that is about to be exported there are no image folder.
the paths my scene seems to use are relative.
Just FYI, I keep getting this in the log file.
13:55:21.7 Info : Export Scene ventuz://scenes/ptz.vzs is exported from memory - not from file!
not sure if this has anything to do with it.
The solution I found is when I add an image node, instead of loading an image directly into the loader, I changed it to texture loader under texture properties. then proceeded with loading the proper texture. Thank you all for your help.
it's true that you have to respect if you load it directly into a node, or use relativ paths, absolut paths etc...
BUT, in this case there is a bug in the Image Node. If you load it directly in the node, it doesn't export the texture.
We will fix this...
We will fix this...
