Render To Disk Never Worked for me in V4 and V5
serourian
Post by serourian » 22 Apr 2016, 21:19
Hi, I'm really frustrated, and don't know why this is happening only with me,because never found a topic like mine.
I am trying to Render to Disk even the simplest scene: a cube rotating, nothing else !!!! When I start render to disk, as soon as it starts it hangs. I tried BMP,PNG, Qt ..... even at very low resolutions .. nothing works :cry:
I did it on my Toshiba Qosmio x70 and x75 computers, it doesn't render.
I tried on desktop computer with Quadro Graphics card on a computer which is $5500 .... and again nothing works.
Why I'm not able to record anything ?!?!?!? Is there any configuration in the card that I shall disable or anable?!??!
please, please help....
I can't make any type of demonstration. I am using Ventuz 4 and V5 designer.
I am using SSD drives.
regards.
Re: Render To Disk Never Worked for me in V4 and V5
Post by chriss0212 » 23 Apr 2016, 16:46
hi serourian,
can't see any problem here. take a look to the video... but remove the .zip at the end of the filename.
greets
renderToDisk.mp4.zip
(1.66 MiB) Downloaded 537 times
lerou
Post by lerou » 25 Apr 2016, 15:01
I've had that issue too. Never tried solving it because I always use a video capture software. Usually the render to disk can't do what I need anyway ;)
Post by Dennis » 25 Apr 2016, 15:16
On my 299€ laptop RTD is working like a charme...
brand new not even updated lappy...
on all my machines here at work the RTD works...
i remember we had a small issue, when the HDD is full, it still renders to disk, but the whole sequence is lost. that should be fixed.
anyway:
Scene->New...->SIMPLE SCENE (the one with the rotating V box)
DONT CHANGE ANYTHING, NOR LAYER FX NOR ANYTHING! :)
click render to disk
set TIME BASED
capture duration 1 (30-60frames depends on config)
output: BMP
fps... 60
alpha: NO ALPHA
check path and basefilename...
back to control and hit render to disk..
anything?
please send over your config and one of the caputured screens...
tyia
:ugeek:
serourian
Post by serourian » 25 Apr 2016, 15:18
It's working like a charm with Chriss!!!
I already opened a ticket with Ventuz customer support.
Here is whats happening with me:( download and remove the .zip at the end of the filename.)
http://www.genius3d.com/VentuzRenderToDisk.mp4.zip
serourian
Post by serourian » 25 Apr 2016, 15:25
No Dennis, it doesn't work for me. I used to use Frapps, Camtasia . .. they all capture screen,but here in Ventuz,no chance at all. Last time to output the render, I used Texture saver, which is not very good, because it drops frames. I need to render as any other package renders, like premiere , Avid . . . or at least like Blufftitler.
I got really exhausted trying all types of file types, sizes and methods.
Post by Dennis » 25 Apr 2016, 15:57
Sou,
in your video i see some things i would like to avoid:
please really..
use NO configuration at all... means:
use for all V5 configurations "None"
start a new project full HD
create a new "simple scene" with the rotating cube
render to disk, time based, NO CODEC choose BMP, NO ALPHA
render to a standard path (like your d:\test)
if it stalls again, ok we have to generate a dump which i will explain later on.
(would be great if you could help us there to solve that issue!)
best regArts
:ugeek:
serourian
Post by serourian » 25 Apr 2016, 16:22
YESSSSSSSSSSSSSSSSSSSSSS!!!!!!!!! FINALLY !!!!!!!!!! It works !!!!!!
here you go:
http://www.genius3d.com/R2DWorksAtLast.mp4.zip
Thank you very much. :P :P :P :D
Post by Dennis » 25 Apr 2016, 16:41
Could you find out whats the issue?
i expect it to be the resolution (720x576)
reg :ugeek: Arts
serourian
Post by serourian » 25 Apr 2016, 17:43
No, I can render at any resolution. It was just because I was putting settings for the video . . . .
When I put all none it really worked.
