i would like to know, on which adresses does ventuz send the legacy osc statistics? this is not documented in venuz5/ventuz4 and ventuz3 only port and ip is documented (port 19299 and ip:255.255.255.1)
thanks and greets
Ventuz Statistics
Re: Ventuz Statistics
hhhmmm...
hi ventuz... isn't it maybe not documented at all or why isn't there an answer?
greets
greets
Hi Chriss!
The OSC address is /VENTUZ/MachineID
It's probably not documented because there is a Ventuz.Kernel.Remoting.MachineSignaturReceiver component in the old Ventuz Remoting (1) which can be used for receiving this data.
hi karol,
thx for info...but...
my machine id is 1 and i use a osc input node. configured with these properties:
osc address: /VENTUZ/1
IP: 255.255.255.1
port: 19299
i don't recieve anything ;(
i am using same machine for sending and recieving, but because it is multicasting it should work, right?
greets
IP: 255.255.255.1
port: 19299
greets
