I am trying to write a phase in a circle like around a cylinder but having trouble doing so, i know I need to use the Text Effects, but as soon as i add them my text disappears. Thanks in advance for your help.
Rotate and Circle Text effect not working Need help
Re: Rotate and Circle Text effect not working Need help
Solution found, when you bring a 3d text or 2d text, disconnect the link between them, then proceed with linking the source of the text to the source of the text effect, and the text result to the text. Enjoy!!!!
