I want to use image sequence frames to achieve some good effects.
But after I use the Movie Frame node and add the image file to the node, the CPU resouces are occupied a lot.
What's worse, after added a little more Movie Frame Nodes, the CPU is 100% occupied...
The images what I used are very small, mostly are only 100kb per picture. The amount of one group of image sequence frames is about 25 pictures.
Is anyone here meet the same problem? How to solve it? T.T
Thanks a lot.
Eric
