i have to use a specific font.
in normal mode numbers are written a bit up and a bit down... in photoshop... if i set the font to "ALL Caps" numbers are vertical all in one line...but not in ventuz if i write the text into the casing node and set it "ToUpper"
any idea?
thx and greetz
Font problem
Re: Font problem
ok...
have a "workaround". i modified the font
i found a cheap font editor!
http://old.fontlab.com/font-editor/typetool/
greets
greets
Re: Font problem
ok...
i am not a font expert, but it seems, that ventuz is only able to show characters which have a unicode code. but in my font there are many characters without this unicode.
greets
greets
Re: Font problem
Hi Chriss!
Ventuz can definitely display characters of a font which do not have a Unicode assigned - otherwise we would not be able to render Arabic words correctly.
We changed the Text layout Engine for V5 and there might be bug.
Could you send me the font file so I can investigate the issue?
Re: Font problem
hi karol,
i will send you the font
but how can i adress an upper case 1 in ventuz?
greets
greets
