Hi all,
Congratulations for your work on ventuz 5 !
It's not possible to use more than one layer in a nested scene. Is it by design or is it because of a technical constraint?
thx
Rob
Multple Layers in scene port
Re: Multple Layers in scene port
There is a difference by using a SCENE PORT and SCENE LAYER -
when using the scene PORT - all layers except the first are not shown
when using the SCENE LAYER - everything should work as expected
best regArts
best regArts
Btw. this is by design!
Layer Blending/FX/PostProcessing works only at the scene root. Loading a scene with multiple layers somewhere to the scene-tree via the SCENEPORT node breaks this mechanism and that's why only the first layer is rendered - without effects.
