Oculus rift example scene problem
Recently I've tried following the rift guide over at http://www.ventuz.com/support/how-use-o ... ity-ventuz. However if i follow all the steps in the video/in the scene, I get the error "Unable to load DLL 'OVR': The specified module could not be found". Any ideas on how to fix this?
Re: Oculus rift example scene problem
It worked for a short time when the OR had the extended mode. However they removed it and therefore this does not work any more.
Hi
I recently purchased OR as well, I haven't had the chance to test it because I'm currently using HTC Vive, But I noticed that I can only see the vive node in ventuz 5 under the VR category.
My question is, for the oculus rift, should I use the same nodes that I use for Vive HMD and controller, or will there be another node if i change the Ventuz configuration once I install the oculus ?
Thank you
Thank you
Hey your post is in the wrong section.. this is for V4Naggar wrote:Hi
Thank you
Anyway to answer your question:
Yes the VR Nodes in V5 : HMD etc is the same for the Oculus Rift - except the controllers.. these will be implemented in an upcoming ventuz release.. so stay tuned.
Right now, you can use the HMD and use the XBOX controller by using a Joystick node.
Best regArts
PS: next time please post in the V5 - HowTo section
PPS: Thanks for using the search function to spot this thread
