Hi there,
when I disable my audio playback device and enable it again, while I'm running a Ventuz presentation (vpr-file), I don't get any audio output of my presentation no more. Is there a solution to solve this problem?
would be happy for any help.
Ben
no audio in presentation after switching playback device
Re: no audio in presentation after switching playback device
Hi Ben,
myself I have no problem to enable/disable audio-node by changing the device in vpr,
Greetings, Stephan
Greetings, Stephan
first I want to say sorry for posting my Topic twice. Maybe an Admin can delete the other Topic, where I descriped the same problem.
Ok, back to my issue... In your post Stephan you said that you don't have this problem when using an Audio Node. So I created a simple test scene including an Audio Clip Node, a Sound Node and a Movie Clip Texture Node. When running my vpr I still get no audio after disabling and enabling my playback device. Just to be sure you got me right: I switched my vpr to window mode by pressing Alt+Return then I right clicked the speaker icon in the lower right of my taskbar, in the playback devices i switched my active device off and on again. After that I won't hear audio out of my vpr any more.
I'm using Ventuz Version 4.07.02.413. Is there anybody who can reconstruct my problem?
Hey Ben,
i will have a look at the other topic.. merge/delete it. no worries
about your problem with the audio node - could you please send over a VZA ?
thank you very much and
creative regArts
creative regArts
