I'm trying to work with a Matrix Array (an array of transform matrices) and I can't find how to assign a matrix to each index.
something like :
MatrixArray[0] = Matrix1;
If someone has some hints to help...
Have a nice day !
Matrix Array in C# script
Re: Matrix Array in C# script
It shouldn't be any different to arrays of any other type.
Are you assigning to the "output matrix" directly? In that case, it wouldn't work, since the output is only allowed to be created once. You'd need something like
Maybe some code and/or debugging infos?
-C
MatrixType[] MOut = new MatrixType[xyz];
// ... assign values to MOut
MatrixArray = MOut;
-C
Thank you very much for your answer which solved a part of my problem.
The second part is : the "MatrixType"
I have miss something but I can't find the right way to decare it. Should I declare a namespace first ?
Thank you.
Thank you.
I found !
1st Declare a namespace just after the "using VentuzKernel;" :
using SlimDx;
2nd to declare a new matrix array :
Matrix[] MyMat = new Matrix[5];
Have fun.
using SlimDx;
Have fun.
