Any plans to support the HAP-Codec natively in Ventuz?
And before asking - why...
Size is in the range of mpeg2, but resolution can be higher than FullHD, quite less usage of CPU and the possibility of Alphachannel.
http://vdmx.vidvox.net/blog/hap
/Thomas
HAP-Codec
Re: HAP-Codec
hi Thomas,
you are not the first
http://forum.ventuz.com/viewtopic.php?f ... odec#p6585
biggest pro of hap is: it is a gpu decoding codec and really pretty fast in decoding. many media servers are already using it and it would be awesome if ventuz would too!
Re: HAP-Codec
It´s not only the fast decompression, but the possibility to use alpha, too.
To answer Dirk´s question from thw thread mentioned by chriss; quality of hap-videos is comparable with mpeg2, when using hap-q quality is better but the size of the file is more than double.
/Thomas
/Thomas
Re: HAP-Codec
hi thomas,
for using alpha you can use huffyuv codec. also very fast and lossless! but: will result in huge file sizes
Re: HAP-Codec
moin chriss,
the hap-videos are delivered by an agency and I have to use them in another application.
Just want to use them in Ventuz too.
/Thomas
/Thomas
u-double-u
Re: HAP-Codec
Hello, another codec supporting alpha-channels would be "Lagarith".
http://lags.leetcode.net/codec.html
cheers.
cheers.
Re: HAP-Codec
but lagarith is extremely performance hungry!
huffyuv is MUCH better here!
Re: HAP-Codec
HAP made it in V5.2
http://www.ventuz.com/ventuz-5-what-is-newFEATURE 8000 Added support for fully hardware accelerated Hap/HapA/HapQ/HapQA video playback.
