when exposing a value for a node that only has one value (like the variables int, float, ..) - it would be awesome if the default exposure name would be taken from the nodes description.
So usually you put in a float node, rename it to "Height". Then you double click to expose the value. You select the name and change it to "Height". Or you're a pro and use copy&paste. However it would be super awesome if you could just click on the expose button and be sure that it uses "Height" as you've already typed that in as the name.
It's just something to reduce cliks but it might also help to convince people to build cleaner scenes
Best,
