Exposed values from a loaded scene with Scene Port
serourian
Post by serourian » 12 Nov 2015, 13:30
Hi all, is there a way to see the exposed value of a scene in another scene loaded via Scene Port??
ie: when I click on the scene port, I can see the exposed values in the loaded scene.
I am writing my own controllers. I don't use Director.
Re: Exposed values from a loaded scene with Scene Port
Post by Karol » 13 Nov 2015, 13:33
Hi!
If you select the ScenePort in the Content Container you can see all exposed properties from the inner scene.
If you want to bind these properties you have to double-click them or click&hold right mouse button and then select 'Edit Interface'.
See attached Ventuz Archive.
ExposingSceneProperties.vza
(5.33 KiB) Downloaded 378 times
