Page 1 of 2
cluster synchronization
Posted: 22 Oct 2015, 01:53
by cy001316
I have two machines for the cluster rendering,they connect to the same local area network.One of the machine's mode networking is the Master another one is the Client.But when I use OSC to control , only one machine of the screen will switch, the other unchanged, that is to say, the picture of another computer without synchronization. How should I solve it?
Re: cluster synchronization
Posted: 22 Oct 2015, 10:14
by joschy
the easy way is to use multicast IP's, take a look at the manual
Posted: 22 Oct 2015, 10:35
by lerou
send OSC to both machines, not only to the master.
Posted: 23 Oct 2015, 03:48
by cy001316
But the OSC software can only write one IP?
Posted: 23 Oct 2015, 03:53
by cy001316
joschy wrote:the easy way is to use multicast IP's, take a look at the manual
Do you means that the Multicast Address in TUIO settings option?
Posted: 23 Oct 2015, 03:54
by cy001316
cy001316 wrote:But the OSC software can only write one IP?
Posted: 23 Oct 2015, 06:48
by Thomas
Thats the reason to use a Multicast Address in settings of your OSC-Software.
It will send the commands to all receiver within the range.
See:
https://en.wikipedia.org/wiki/Multicast_address
Posted: 23 Oct 2015, 07:31
by cy001316
So I need to set the two machines to client and master, respectively. Or two machines are set to single?
Posted: 23 Oct 2015, 07:41
by lerou
cy001316 wrote:Thomas wrote:So I need to set the two machines to client and master, respectively. Or two machines are set to single?
Question is, what are you doing?! The Master/Client setting you're talking about is used for the interaction (TUIO).
If you're just using OSC to control things (like starting an animation) that has nothing to do with that setting. In that case you just send your OSC signal to all cluster machines - by using Multicast. The cluster sync is implicitly active if you set up your cluster correctly (same group ID, different IDs for the machines). The lowest ID becomes the master for the cluster clock.
Best,
Posted: 23 Oct 2015, 09:20
by cy001316
lerou wrote:cy001316 wrote:Thomas wrote:So I need to set the two machines to client and master, respectively. Or two machines are set to single?
Best,
Thank you for your reply.
I was a novice, is a beginner, the first use of ventuz cluster rendering, I want to do is to use OSC control in the cluster two machines. Now the problem is that OSC can only control a machine,if I do not use multicast address, can achieve?
