cluster synchronization
I have two machines for the cluster rendering,they connect to the same local area network.One of the machine's mode networking is the Master another one is the Client.But when I use OSC to control , only one machine of the screen will switch, the other unchanged, that is to say, the picture of another computer without synchronization. How should I solve it?
Re: cluster synchronization
the easy way is to use multicast IP's, take a look at the manual
But the OSC software can only write one IP?
Do you means that the Multicast Address in TUIO settings option?joschy wrote:the easy way is to use multicast IP's, take a look at the manual
But the OSC software can only write one IP?cy001316 wrote:But the OSC software can only write one IP?
Thats the reason to use a Multicast Address in settings of your OSC-Software.
It will send the commands to all receiver within the range.
See:
https://en.wikipedia.org/wiki/Multicast_address
See:
Thomas wrote:Thats the reason to use a Multicast Address in settings of your OSC-Software.
See:
So I need to set the two machines to client and master, respectively. Or two machines are set to single?
Question is, what are you doing?! The Master/Client setting you're talking about is used for the interaction (TUIO).cy001316 wrote:Thomas wrote:So I need to set the two machines to client and master, respectively. Or two machines are set to single?
If you're just using OSC to control things (like starting an animation) that has nothing to do with that setting. In that case you just send your OSC signal to all cluster machines - by using Multicast. The cluster sync is implicitly active if you set up your cluster correctly (same group ID, different IDs for the machines). The lowest ID becomes the master for the cluster clock.
Best,
lerou wrote:Question is, what are you doing?! The Master/Client setting you're talking about is used for the interaction (TUIO).cy001316 wrote:Thomas wrote:So I need to set the two machines to client and master, respectively. Or two machines are set to single?
Best,
Thank you for your reply.
I was a novice, is a beginner, the first use of ventuz cluster rendering, I want to do is to use OSC control in the cluster two machines. Now the problem is that OSC can only control a machine,if I do not use multicast address, can achieve?
