Slider Example
fliplab
Slider Example
Post by fliplab » 28 Apr 2015, 16:27
This is simple example of slider, can anybody help and fix errors?
slider.vza
(31.29 KiB) Downloaded 290 times
Re: Slider Example
Post by chriss0212 » 29 Apr 2015, 10:07
first of all: you should try to avoid c# scripts as much as you can, because it slows down ventuz! if you can: use expressions!
i tried to rebuild your scene...don't know if it is realy what you expect...but a good starting point ;)
SlideShow2.vza
(31.01 KiB) Downloaded 293 times
