hi all,
currently have a device that is giving me rotation values -360 to 360 but want to convert to make the object rotate without
jumping back so the rotation is continuousness. have attached clip to show the issue.
https://drive.google.com/file/d/0B1yZCF ... sp=sharing
rotation help
Re: rotation help
hi,
don't use absolute values, use deltas of your incoming angles (current value minus value from last frame) and sum them up.
cheers,
cheers,
Re: rotation help
hi,
are you using a math effect between device input and rotation? if so, set modulo to 360.
