When I try to add a .obj file through "Import" > "Geometry" I succeed adding the geometry into my hierarchy. But it does not show on my Renderer.
I have not changed anything in my options after a clean install.
Thanks in advance!
Problem adding geometry
Re: Problem adding geometry
Hi!
Do you see the object in the Import Preview?
Probably your object is out of view if its imported to the scene!
In the Import Preview change the XYZ alignement to Center. This could help.
Another problem could be inverted normal vectors or a wrong winding order of the geometry faces.
I can see it in the preview yes, I tried every option before importing
i sometimes get the same issues when i import model, this is because i have exported the model to large have you tried to scale down to 0.01 and turn on bounding box you should see it.
