Touch node depends on Projection
lerou
Post by lerou » 25 Feb 2015, 12:16
I am working in a pixel space. I created an ortho projection with the screen dimensions. Elements are scaled using pixels - so a button could have something like 200px. I am using a lot of touches. So far no problem.
Now I want to use the touch transform's inertia behaviour - and I can't really. The deceleration factor behaves differently depending on the projection. I expected it to only depend on the speed the element is moving with. Even with deceleration set to 1 (the maximum) my elements are flying far too long before stopping.
how can I solve this?! And no, I can't go and change all projection settings and scales and values...
lerou
Re: Touch node depends on Projection
Post by lerou » 25 Feb 2015, 12:24
here's an example. Try throwing the rectangle around in both modes.
cheers,
Throw_away_002.vza
(59.14 KiB) Downloaded 285 times
