it seems, that touchWhile reset is not doing what i expect. if i enable this feature the node is not reseting while touching. i can not find any option combination where the node is reseting to the reset values without loosing the touch.
TouchTransformation TouchWhileReset
Re: TouchTransformation TouchWhileReset
Hi Christian!
I don't know what you mean!
Both modes (ResetWhileTouch & TouchWhileReset) are working as expected - at least in my small test scene.
Do you have a reproduce for us?
mmmhhhh......
if you enable touch while reset....and you keep an object touched...and you press reset....the object is resetting to the reset values....and the touch on the object is still alive? if i make a reset during moving....nothing hapens.
but maybe i have another meaning of touch while reset in mind
- touchWhileReset.vzs
- (5.2 KiB) Downloaded 318 times
