Interpolation.Active not working on Math Effects
schub
Post by schub » 21 Jan 2015, 16:39
the interpolation active boolean does not take effect until the target value has changed a second time.
I tested it with the new ease node in linear mode also, it has the same bug.
I believe it applies to all the math effects.
Interpolation_Bug_v001.vzs
(18.87 KiB) Downloaded 554 times
Bug is visible in 2nd row, the animation i wanted to create is in the 3rd row (disregard the slight delay, I had to use a different animation method to show what effect I wanted)
schub
Re: Interpolation.Active not working on Math Effects
Post by schub » 21 Jan 2015, 17:47
I'm afraid fixing this "bug" could break some logic that relies on this behaviour..
A collegue suggested switching the duration value instead, this seems to work for now.
I would still welcome some feedback on this case.
Greets
-schub
