Slide Mangager Copy & Paste fails
joysprod
Post by joysprod » 14 Jan 2015, 15:27
Ventuz version 4.06
Using an existing scene built in a previous version. I can no longer copy a slide by either copy and pasting. (Used to give an error but would paste the slide at the bottom of the Slide Managaer, allowing you to drag to a new output of the slide manager.)
or by Cntrl dragging to a new Slide Manager Output
Error reports :-
HE Error
Drag & Drop Operation failed
missing version tag
Also I cannot copy the content of the slide and paste into a new slide - same error
Looking for a workaround to duplicate slides. Show coming up next week!!
joysprod
Re: Slide Mangager Copy & Paste fails
Post by joysprod » 14 Jan 2015, 17:05
Have now been able to research this further. It appears to be when the control of a keyframe animation node is exposed and then connected to another key frame animation node outside of the container. All of this is sitting inside a slide node. I dont know if this new to the latest 4.06 release or exists in earlier V4's?
bug.vza
(6.99 KiB) Downloaded 356 times
Post by Karol » 16 Jan 2015, 16:30
Confirmed!
Sorry, this has been broken in 4.06 - is working in 4.5.2!
We will fix it with an 4.06 update.
