If you have an array of lets say 5 entries (indexes from 0 to 4) and you want to delete only the last entry (remove index 4, length 1),
firing the remove method changes nothing to the output Array. The entry is still there.
However if you want to remove the last two entries (index 3, length 2) the Remove Method works as expected.
This applies to all array types I tested it with (string, int, float, byte) and all lengths.
Array Mixer does not delete last entry
- array_mixer.vza
- (5.97 KiB) Downloaded 438 times
Re: Array Mixer does not delete last entry
Oh yeah!
That was easy
Just replaced '<' with '<='
Fixed for Ventuz 4.6.0
That was easy
Cool, Thank you.
Sometimes its the little things.
