Stacked gestures: paint over and translation/tap?
mrmacmusic
Post by mrmacmusic » 02 Dec 2014, 11:38
I'd like to be able to use two-finger touch gestures (pinch/zoom) to scale a texture but also be able paint over the same texture, however I can't work out how to do this and wonder if it is even possible. So far I can do either or but not both – the paint node has to be disabled to allow the underlying translation node to take effect. Any ideas..?
I'm also wondering if it is possible to capture a 'double tap'..?
lerou
Re: Stacked gestures: paint over and translation/tap?
Post by lerou » 03 Dec 2014, 11:20
as far as I know it's not possible to have several input areas on top of each other. Only one would get the events.
As for your double tap: you can build a logic for that using two nodes. See attached example.
cheers,
DoubleTap.vza
(12.56 KiB) Downloaded 341 times
