I use Ease node to control some axis animation, but if I set the duration to 0s, the node won't work.
The other Math Effect node such as Linear, Damper can work if set the duration to 0s, but it is so convernient for me to use Ease node when I need to change the math function.
Drac Zhang
About Ease node
Re: About Ease node
hi
dont know the sense of a ease node with 0 as time...but you are right it doesnt work...
workaround: make time loweset for eg 0,001s....and it works as expected
Re: About Ease node
You are right!
This is inconsistent with the behaviour of Damper, Linear and Decay node and should be changed.
