Linear Node Error
Drac Zhang
Linear Node Error
Post by Drac Zhang » 26 Aug 2014, 05:23
I have a problem about linear node.
I just link the linear node to C#,and also set changed=true in the script. But every time I first open the scene, the linear node doesn't set to the correct value.
You see, there's no such value input. But the linear output value is so strange. But all the other linear linked to the same C# is OK. After I select the UseTarget2 and then unselect it, it just work well.
It's so annoying to select it everytime when I open the scene.
So does it has some ways to solve it?
Drac Zhang
Götz_B
Re: Linear Node Error
Post by Götz_B » 26 Aug 2014, 09:24
Could you attach a scene with the error? So we might figure out whats the problem is.
Drac Zhang
Post by Drac Zhang » 26 Aug 2014, 10:01
I try delete the linear node,and the create a new to do the same thing.
Now it works well and I can't reproduct it.
Best Regard
Drac Zhang
Daniel Willer
Post by Daniel Willer » 27 Aug 2014, 09:12
Maybe auto save is enabled and you can provide a revision of the scene?
Daniel
Drac Zhang
Post by Drac Zhang » 27 Aug 2014, 14:13
My autosave saves every 5 minutes and the old one seem had been recovered.
I also have this problem in the other projects, but it also works well after I delete it and re-creat it.
So I will upload when I next time meet. And I found that the linear node seems have this problem just when it linked to a C# node.
Drac Zhang
Drac Zhang
Post by Drac Zhang » 29 Aug 2014, 06:33
Hi Daniel,
I met that problem again.
But after I copy it to a new scene and try to export it, it work correct again. So strange...
And now I'm certain it will only have this problem when it linked to a script node. But I just output 0 or 100.
Drac Zhang
