homographic correction in warping tool
Post by chriss0212 » 13 Jun 2014, 07:10
hi dierk
i missing (or just didn't find) a very important feature in the warping tool. if you have a projection just with some keystoning normaly it should be enough to adjust only the 4 corner points. but a keystoned projection is resulting linear distotions in the texture. at the moment you need many points to adjust it...but a "keystone filter" with homographic correction would help here A LOT.
please see attached scene....and try to adjust ;)
greetz and thx
keystone.vza
(18.2 KiB) Downloaded 499 times
Dierk Ohlerich
Re: homographic correction in warping tool
Post by Dierk Ohlerich » 13 Jun 2014, 11:43
Fortunately improving the shaping tool is on the roadmap for Ventuz 4.5, and I am just starting with it :-)
If i understand correctly, keystoned projection lead to a perspective, non-linear distortion that is hard to compensate with the Bezier patches I use for warping.
If that is the problem, then it should be easy to add an option for that.
-- Dierk Ohlerich
Post by chriss0212 » 13 Jun 2014, 13:57
jepp....thats it ;)
thx and greetz
Post by chriss0212 » 18 Jun 2014, 18:00
hi dierk
.......it seems that all of it is already possible ;)
https://www.hightail.com/download/ZUcxS ... TW1Ga2NUQw
