Audio embedded - how to config
bergemy
Using a Deltacast HD key, how do I config the audio output in the configuration editor? I can see that I have a ventuz broadcast audio device here but no Deltacast option. Is this right?
Re: Audio embedded - how to config
I don't have a Deltacast card installed so I can't walk you through the process.
But when you want to route audio, double-check if you:
Right click on the Ventuz Machie Service Icon in the tray and select 'About' to check.
- enabled the device in the 'Audio' tab
- created a new cable in the 'Cross Points' tab
