Controlling visibility of a node
How to control visibility of a node? Not in Designer. Basically I need to animate visibility of a node and somehow do not want to use alpha for this.
Re: Controlling visibility of a node
You can animate the nodes blocked property, however this will be on/off only.
Why is using the alpha node a problem?
try this
- AnimatedFade.vza
- (11.22 KiB) Downloaded 394 times
