(1) it is not ’System.Diagnostics.Debug.WriteLine('abcd');
How to output 'abcd' in message view?
(2) if I create two script, A and B, how to call a method that belong to A from B.
as non native language beginner, thank you for your help.
How to output debugging message in message view?
Re: How to output debugging message in message view?
(1): Use or
(2): This is only possible via binding output Event from B to input Method to A.
(1): Use
VLog.Info("Script", "This is a Info message", VPopup.Never);Code: Select all
VLog.Error("Script", "This is an Error message", VPopup.Never);Cheers
