I keep having director crash when choosing the show to launch. This is ventuz 4.03.00. I have tried to uninstall reinstall and repair with no luck so far.
"Fatal Error in Director Unhanded exception: Object reference not set to an instance of an object"
Attached is a copy of the last launch/crash of director log file(had to zip the .txt). I could not send the log/error report from the machine because i can't get internet to it.
Thank you!
-sherman
Director crash when launching project.
- shermanpat
- Director error.txt.zip
- (1.48 KiB) Downloaded 547 times
-Sherman
Meru Interactive
Meru Interactive
Re: Director crash when launching project.
Hi Sherman!
Does this happen with every Director Show? Even with the pre-installed?
Do you have a custom AV configuration (Ventuz Configuration Editor)?
- shermanpat
I believe it did this on first launch and with all projects(sample and mine).
But it was a group of us all playing around getting a cluster controlled. I was able to get a different machine working so I will see if i can just use a working auto.xml files that i know works. Then also reset the config files and see what happens.
If I can't get that to work I will let you know here.
Thanks for point me toward the fix.
Loving the director! I have so much more to learn...
-Sherman
Meru Interactive
Meru Interactive
