I have just spent over 4 hours trying to get a cluster sync between two machines with V4. It just does not want to work. I know the hardware setup regarding router and Ethernet is good as I get an immediate cluster sync (turns green) under Ventuz 3 on the same machines.
I have also noticed that according to your notes under "How to: Cluster Rendering" when viewing the on-screen statistics I should see before the (:) the Group ID followed by the machine ID. In my case I see the correct Group ID but the machine ID on both machines is always at 00. I do in fact have them set to 01 and 02 so something doesnt seem to be correct.
Do you have any ideas where I can trouble shoot further?
No Cluster Sync
Re: No Cluster Sync
hi peter
are you working in the designer? if so: have you switched to production preview in the stage editor?
Re: No Cluster Sync
Agh... that was something I didnt even consider or realize that setting the Production Preview on each machine would make such a difference with Cluster Sync, and give me values after the (:)
Having said that, it's still not working!
My testing set up is as follows:- I have two machines A & B and a simple setup of 1 output per machine, giving a cluster resolution of 3840 x 1080.
I set my Group ID for both machines to 1
I make machine A the Master as regards Cluster and give it the ID 1
I make machine B the Client and give it the Same Group ID (1) but sets its ID to 2
I go to A and ensure that it is set to Master in the Config Editor and machine B is set to client.
I start both Designers and set machine A to Production Preview ID1 and machine B to Production Preview ID2
Turning on the statistics: Machine A shows ID 01.01: "Cluster Clock" -01
Machine B shows ID 01.02 : "Cluster Clock" -02
I thought that on the client machine, the number after the cluster clock was the ID of the master machine? In this case it should show 01, but it shows 02. It looks to me that somehow the clock is not getting through to the client machine. I'm still at a loss as to why it is not working.
Re: No Cluster Sync
the settings you described look correct so far. Besides that it is strange to setup two Designer in a Cluster
Are you sure there is no firewall blocking Ventuz 4?
Götz
Götz
